Using Siebel Tools > Reference Materials for Siebel Tools > Dialog Boxes That Set Development Options >
Development Options for Project Checkin and Project Checkout
Table 46 describes the development options that you can set for project checkin and project checkout. For information about using this dialog box, see Specifying the Data Source That Siebel Tools Uses and Configuring Third-Party Code Control. For more information about projects, see Checking Out and Checking In Projects and Objects.
Table 46. Development Options for Project Checkin and Project Checkout
Enable Source Control Integration |
Allows Siebel Tools to create an archive for each project that you check in. |
Show Execution of the Integration Batch File |
Allows Siebel Tools to display a DOS window when the srcctrl.bat batch file runs. You can use this window for diagnostic purposes and to assist with debugging a custom batch file. |
Specifies the location of the srcctrl.bat batch file that Siebel Tools uses. This file includes instructions that the code control software uses to do checkin or checkout. |
