Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger > Tracing a ScriptYou can run a trace on an allocation, event, or SQL command. You can start a trace for a user account, such as your development team. The Siebel Server saves the trace information to a log file. Tracing a script is not the same as tracing a file. For more information about tracing a file, see the information that describe the Trace, TraceOn, and TraceOff methods in Siebel Object Interfaces Reference.
Example of a TraceThe following code is an example of a trace that Siebel Tools creates after the Business Service Simulator runs: ObjMgrExtLangLog ObjMgrExtLangLog 0 00000080475f1578:0 2007-12-12 07:33:45 [User: ] SQLBIND, 90, 1, Y. ObjMgrExtLangLog ObjMgrExtLangLog 0 00000080475f1578:0 2007-12-12 07:33:45 [User: ] COMPILE, END, <unknown>. ObjMgrExtLangLog ObjMgrExtLangLog 0 00000080475f1578:0 2007-12-12 07:33:45 [User: ] EVENT, BEGIN, Service [sam], Service_PreInvokeMethod. ObjMgrExtLangLog ObjMgrExtLangLog 0 00000080475f1578:0 2007-12-12 07:33:45 [User: ] EVENT, END, Service [sam], Service_PreInvokeMethod. ObjMgrExtLangLog ObjMgrExtLangLog 0 00000080475f1578:0 2007-12-12 07:34:39 [User: ] SQLSTMT, 91, Example of a Detailed TraceThe following code is an example of a trace that Siebel Tools creates if the log level is set to high. For brevity, only part of this log file is included: 2021 2007-12-12 07:46:29 2007-12-12 07:56:46 -0700 000003fd 001 003f 0001 09 SCCObjMgr_enu 11534365 5452 780 d:\21022\ses\siebsrvr\log\SCCObjMgr_enu_0011_11534365.log 8.1 [21022] ENU ObjMgrLog Info 3 000000b9475f1578:0 2007-12-12 07:46:29 (modpref.cpp (949)) SBL-DAT-50803: SharedFileReader: D:\fs\userpref\SADMIN&Siebel Universal Agent.spf_SDCHS21N625_5452_780: File succesfully opened. ObjMgrLog Info 3 000000b9475f1578:0 2007-12-12 07:46:29 (modpref.cpp (949)) SBL-DAT-50804: LoadPreferences: D:\fs\userpref\SADMIN&Siebel Universal Agent.spf: Preferences succesfully loaded. ObjMgrExtLangLog ObjMgrExtLangLog 0 000000b9475f1578:0 2007-12-12 07:46:29 [User: ] SQLSTMT, 1, SELECT, SELECT T1.CONFLICT_ID, ObjMgrExtLangLog ObjMgrExtLangLog 0 000000b9475f1578:0 2007-12-12 07:46:29 [User: ] SQLBIND, 1, 1, 16:sdchs21n625:4330siebel. Declaring Functions and Procedures in Siebel VBThe Siebel Compiler compiles Siebel VB functions and procedures in alphabetical order for each object definition. If a function or procedure calls another function or procedure that is not defined, then the compiler creates an error message that is similar to the following: function_name Is An Unknown Function To avoid this error, you must use the Declare statement to declare the function or procedure in the general declarations section. Siebel eScript does not require you to declare these functions. For more information, see Siebel VB Language Reference. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
