Using Siebel Tools > Customizing Objects > Examining Objects >
Searching the Repository
This topic describes how to locate object definitions for multiple object types. For information about how to locate object definitions for a single object type, see Locating and Modifying Object Definitions in the Object List Editor. If you know that one or more properties includes a value, then you can search the repository across all properties of multiple object types to locate the objects that include this value. To search the repository
- Click the Tools menu, and then click Search Repository.
Searching the repository can consume a significant amount of time. You can click Cancel in the Search Repository dialog box to cancel a search at any time while the search runs.
- In the Search Repository dialog box, in the Parameters section, enter the search criteria in the Search value window.
- To limit the search to values that are case-sensitive, make sure the Case Sensitive check box contains a check mark.
For example, select this check box to locate objects that include a value of Account and not account.
- To limit the search to values that match the entire search string that you enter in Step 2, make sure the Exact Match check box contains a check mark.
- In the Types to Search list, choose the object type that Siebel Tools must search.
Note the following:
- Click Search Now.
Siebel Tools runs the search and lists the results in the window at the bottom of the Search Repository dialog box. This window lists all the objects that match the search criteria. It includes the following columns:
Type |
Object type of the object that the search returns. |
Name |
Name of the object that the search returns. |
Property |
Property name of the object that the search returns. |
Value |
Property value of the object that the search returns. |
- To display the object definition of an item that the search returns, double-click this item in the results window.
Siebel Tools displays the object definition of the item in the Object List Editor.
- To export the search results to a file, click Export.
