Using Siebel Tools > Localizing Strings and Locale Data > Using the Locale Management Utility >
Finding Objects That the Locale Management Utility Modifies
This topic describes how to find objects that the Locale Management Utility modifies. To find objects that the Locale Management Utility modifies
- Click the Tools menu, Utilities, and then click Locale Management.
- In the Locale Management dialog box, in the Options tab, in the Languages section, choose the source language and the target language.
- In the Objects section, choose the application or project that you want to localize.
For more information about projects, see Checking Out and Checking In Projects and Objects.
- Click the Modified Objects tab.
- In the Search Criteria section, make sure the Changed Since check box includes a check mark.
- Click the Changed Since drop-down arrow, and then choose the date that the Locale Management Utility must use as the starting date for the search.
- Click Start.
