Using Siebel Tools > Localizing Strings and Locale Data > Using the Locale Management Utility > Using the Command Line to Run the Locale Management UtilityYou can use the command line to run the Locale Management Utility. The commands that this topic describes use the following format:
You must include the absolute path with any file name that you specify. For example, if you specify the export file as
It does not create it in the following folder:
Using the Command Line to Export Strings and Locale PropertiesThe command that this topic describes allows you to export localizable properties for all projects or for all applications. You can specify one of the following values:
FormatThis command uses the following format: /lmu Project ParameterThe Locale Management Utility includes the following parameter: You can use it to identify the projects to export. This parameter identifies the name of an ASCII text file that includes a list of projects that are delimited by a line feed. If you do not include the project_file parameter, then the utility exports all projects. You can use the ExampleThe following command exports properties: siebdev /u sadmin /p db2 /d server /lmu ENU FRA export proj all C:\temp\my_proj_results.slf C:\temp\proj_to_exp.txt This example exports all string properties and language override properties for the projects that the following file lists: It exports these properties to the following file:
The source language of the file is English-American (ENU) and the target language is French (FRA). Using the Command Line to Import a FileThe command that this topic describes allows you to import a file. If the source string in the import file is different than the source string in the repository, then it marks the target locale object as Redo. FormatThis command uses the following format: /lmu ExampleThe following command imports a file: siebdev /u sadmin /p db2 /d server /lmu ENU FRA import "C:\Program Files\Siebel\8.0\Tools\objects\results.slf" This example imports the
The source language of the file is English-American (ENU) and the target language is French (FRA). The file includes all localizable string properties and language override properties. Using the Command Line to Export Strings That Require TranslationThe command that this topic describes allows you to export all untranslated strings and strings marked with the Redo flag to a file. It can export all projects or all applications. The exported file includes the related view names. FormatThis command uses the following format: /lmu ExampleThe following command exports strings that require translation: siebdev /u sadmin /p db2 /d server /lmu ENU FRA todo app "C:\Program Files\Siebel\8.0\Tools\objects\results.txt" This example finds all untranslated strings and redo strings for all applications. It exports the results to the following file:
The source language is English-American (ENU) and the target language is French (FRA). |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
