Using Siebel Tools > Localizing Strings and Locale Data > Configuring Symbolic Strings >
Creating a Project for Your Symbolic Strings
The Symbolic String project is very large. Checking in or checking out the entire project might consume a significant amount of time. It is recommended that you do not check out the entire Symbolic String project. Instead, you can create a new project and set the Project property for any new symbolic string you create to reference this project. For more information about projects, see Checking Out and Checking In Projects and Objects. To create a project for your symbolic strings
- Log in to Siebel Tools.
- In the Object Explorer, click Project.
- In the Projects list, create a new project.
For example, create a new project named CompanyXYZ New Symbolic String.
- Make sure the Locked property contains a check mark.
