Using Siebel Tools > Localizing Strings and Locale Data > Configuring Symbolic Strings > Modifying a Predefined Symbolic StringYou can modify a predefined symbolic string, which is a string that comes predefined with Siebel CRM. It includes a CAUTION: It is recommended that you do not modify a predefined symbolic string. Instead, it is recommended that you create a new symbolic string that includes the text you require. It is recommended that you do not modify the display value of a predefined symbolic string. Siebel CRM might use this display value throughout the Siebel client. For a monolingual deployment, you risk modifying text in the Siebel client that you do not intend to modify. For a multilingual deployment, you risk breaking the relationships between display values for different languages. For more information, see Creating a New Symbolic String. To modify a predefined symbolic string
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
