Using Siebel Tools > Managing Repositories >
Deleting Repositories
This topic describes how to delete a repository. To delete repositories
- Back up the repository that you plan to delete.
If you delete a repository, then Siebel CRM removes all records that the repository contains.
- In Siebel Tools, display the Repository object type.
For more information, see Displaying Object Types in the Object Explorer.
- In the Object Explorer, click Repository.
- In the Repositories list, click anywhere in the row for the repository that you want to delete.
- Click the Edit menu, and then click Delete Record.
CAUTION: To improve performance, it is recommended that you delete obsolete repositories. Deleting a repository requires a significant amount of time and requires resources, such as rollback segments, cursors, tablespace, and so on. Consult your DBA before you delete a repository.
- Click outside the record to save the deletion.
