Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger > Validating Script SyntaxThe debugger includes a syntax checker that you can use to make sure your script compiles properly. CAUTION: The Check Syntax feature identifies only syntax errors and errors that occur if an object or variable is not initialized. It does not identify other types of errors and it cannot trap an error that might cause a run-time error. It examines only script that is attached to the current active object. If an error exists in another script, then you cannot compile the repository.
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
