Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Palettes Window
The Palettes window is a window that allows you to add items to an object. For more information, see Editors That Include a Canvas.
To use the Palettes window
  1. Open the editor that you use to edit an object.
    For example, to edit an applet layout, you open the Applet Layout Editor. When you open an editor, Siebel Tools displays the Palettes window. For an example that uses the Applet Layout Editor, see Using the Applets Window.
  2. Drag, and then drop items from the Palettes window to the editor.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
