Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Using the Controls/Columns WindowThe Controls/Columns window is a window that displays the controls and list columns that you can add to an applet layout if you use the Applet Layout Editor. You drag a control or list column from the Controls/Columns window, and then drop it in a placeholder in the Applet Layout Editor in the same way that you drag an applet from the Applets window. If you choose a control or a list column in the Controls/Columns window, then the Properties window displays the properties for the object that you choose. The Controls/Columns window includes the following items:
For an example that describes usage that is similar to usage for the Controls/Columns window, see Using the Applets Window. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
