Using Siebel Tools > Using Siebel Tools > Using Editors in Siebel Tools > Specifying the Web Template EditorThe Web template editor is an application that is external to Siebel Tools that allows you to edit a Web template. For example, if you right-click a Web template in the Web template explorer, then Siebel Tools opens the editor that you specify and displays this Web template in the editor. You can specify the external application that Siebel Tools opens. This task is a step in Roadmap for Setting Up and Using Siebel Tools. |
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
