Using Siebel Tools > Using Siebel Tools > Using Editors in Siebel Tools >
Using a Layout Editor
Siebel Tools includes the following layout editors:
- Applet Layout Editor
- View Layout Editor
- Web Page Layout Editor
- Applet Menu Layout Editor
A layout editor allows you to do the following:
- Add or map a control or list column to an applet layout.
- Modify an existing view or create a new view. You can drag and drop an applet to the View Layout Editor. You can view a list applet, a form applet, or the container page in Preview mode.
- Add or delete a control from a Web page template, modify a control property, or map a control to a placeholder.
- Edit the menu structure of a Siebel application. You right-click an applet in the Object List Editor, and then click Edit Web Menus.
- Preview an approximation of how Siebel CRM displays an applet or a Web page at run time.
For more information about using layout editors, see Configuring Siebel Business Applications. To use a layout editor
- In the Object List Editor, locate the object that you want to modify.
You can open a layout editor from an applet, view, or Web page. For more information, see Locating and Modifying Object Definitions in the Object List Editor.
- Right-click the object that you located in Step 1, and then click Edit Web Layout or Edit Web Menus.
