Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Close All Files MethodThe Close All Files method closes every open file and writes to disk any data that currently resides in the operating system buffers. It does not return a value. FormatThis method does not include any arguments. ExampleThe following example creates a file, puts the numbers 1 through 10 in this file, and then attempts to get past the end of the file. The On Error statement handles the error and Siebel VB continues to the Debugger code. This code uses the Reset statement to close the file before it exits: Sub Button_Click Debugger: |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
