Siebel VB Language Reference > Methods Reference for Siebel VB > File Control Methods > Copy File MethodThe Copy File method copies a file. It does not return a value. You cannot use the following wildcards in any of the arguments: The Copy File method cannot copy the file that the source argument identifies in the following situations:
FormatFileCopy [path1]source, [path2]target The following table describes the arguments that you can use with this method. ExampleThe following example copies one file to another file: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
