Siebel VB Language Reference > Methods Reference for Siebel VB > Date and Time Methods > Convert String to Time MethodThe Convert String to Time method converts a string to time. It returns a variant of date variable type that represents a time in one of the following ranges: For more information, see Variants. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example writes a variable to a file according to a comparison of the last saved time and the current time. It dimensions the variables that it uses for the Convert String to Time method as double. It does this to make sure the calculations work correctly according to their values: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
