Siebel VB Language Reference > Methods Reference for Siebel VB > Date and Time Methods > Get Current Date and Time MethodThe Get Current Date and Time method returns the current date and time as a date variable type according to the setting of the computer date and time. For more information, see Variants. You can use the Set String Format method to specify the format that Siebel CRM uses to display the date and time. FormatThis method does not include arguments. ExampleThe following example finds the month in the range of 1 through 12 and the day in the range of 1 through 31 for this Thursday. For another example, see Set String Format Method: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
