Siebel VB Language Reference > Methods Reference for Siebel VB > Date and Time Methods > Set Time MethodThe Set Time method sets the computer time. It does not return a value. If the value in the expression argument is not already a date variable type, then this method attempts to convert it to a valid time. It recognizes the time separator characters defined in the International section of the Microsoft Windows Control Panel. For more information, see Variants. FormatThe following table describes the arguments that you can use with this method. Usage of the Dollar SignIf you include the dollar sign ($), then the following items apply:
If you do not include the dollar sign ($), then the following items apply:
ExampleThe following example modifies the time of the computer clock: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
