Siebel VB Language Reference > Methods Reference for Siebel VB > Object Querying Methods > Is Variable Numeric MethodThe Is Variable Numeric method determines if the value of a variable is numeric. It returns one of the following values:
If numeric input is required, then you can use the Is Variable Numeric method to determine if the value that the user provides is a valid number before converting the input to a numeric data type. For more information, see Variants. FormatThe following table describes the arguments that you can use with this method. Related Topics |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
