Siebel VB Language Reference > Methods Reference for Siebel VB > Financial Methods > Calculate Net Present Value MethodThe Calculate Net Present Value method calculates, and then returns the net present value of an investment according to a stream of periodic cash flows and a constant interest rate. This method does the following:
The value that the rate argument contains is the decimal equivalent of the discount rate. For example, if the discount rate is 12%, then the rate is 0.12. FormatThe rate argument for this method describes the discount rate for each period. For a description of the valuearray argument, see Arguments You Can Use with Financial Methods. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
