Siebel VB Language Reference > Methods Reference for Siebel VB > Error Handling Methods > Get Error Message MethodThe Get Error Message method returns the error message that corresponds to an error code. If it does not find an error message that matches the error code, then it returns a null string (""). For more information, see Error Code and Error Text for Siebel VB Errors. FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleThe following example uses the Err statement to print the error number and the text of the error. If an error occurs during an attempt to open a file, then it uses the Error$ statement: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
