Siebel VB Language Reference > Methods Reference for Siebel VB > Error Handling Methods > Resume StatementThe Resume statement stops the code that handles an error, and then passes control to the statement that immediately follows the statement where the error occurred. It does not return a value. If you use Resume [0], then control passes to the statement where the error occurred. The location of the error handler that handles the error determines where code resumes:
Format AFormat BFormat CArgumentsThe following table describes the arguments that you can use with this method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
