Siebel VB Language Reference > Methods Reference for Siebel VB > Error Handling Methods > Simulate Error MethodThe Simulate Error method simulates the occurrence of an error. Note the following:
FormatThe following table describes the arguments that you can use with this method. Using a Custom Error CodeA custom error code must use a value that is greater than any value that Siebel VB uses for a predefined error code. To avoid using a predefined error code, it is recommended that the value you use for a custom error code start with 32,767. For subsequent custom error codes, you can work down from 32,767. CAUTION: Do not use any error code in the range of 4000 through 4999. These are predefined codes for Siebel VB methods. For more information, see Siebel Object Interfaces Reference. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
