Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Get Characters From File MethodThe Get Characters From File method returns a string that contains the characters that it reads from a file. It advances the file pointer according to the number of characters it reads. Unlike the Parse File Contents method, the Get Characters From File method returns every character it reads, including carriage returns, line feeds, and leading spaces. The input buffer can hold a maximum of 32K characters. If the Get Characters From File method must get an amount of data that exceeds this maximum, then you must call it multiple times, processing 32K characters each time you call it. FormatInput[$](number, [#]filenumber) For information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
