Siebel VB Language Reference > Methods Reference for Siebel VB > File Input and Output Methods > Get File Offset MethodThe Get File Offset method determines the current offset of a file. It returns a value depending on the following mode that it uses to open the file:
The offset starts at 0 in a random file or binary file. A position starts at 1. For more information, see Get File Position Method. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example creates a file of account numbers that the user enters. When the user finishes, it displays the offset of the file of the last entry that the user made: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
