Siebel VB Language Reference > Methods Reference for Siebel VB > Code Setup and Control Methods > Call Subroutine MethodThe Call Subroutine method is a control structure that directs flow to a subroutine or function. It returns one of the following values:
You can use this method to call a subroutine or function that is written in Visual Basic or to call C code in a DLL. A Declare Procedure method must describe this C code and it must be implicit in the application. You must make sure the DLL is present on every Siebel Server. For more information, see Declare Procedure Method. If you use the Call Subroutine method, then it is recommended that you use the following guidelines: Format ACall subroutine_name [(argument_list)] Format B
ArgumentsThe following table describes the arguments that you can use with this method. ExampleThe following example does the following:
Related Topics |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
