Siebel VB Language Reference > Methods Reference for Siebel VB > Code Setup and Control Methods > Get Environment Setting MethodThe Get Environment Setting method returns the string setting that is assigned to an environment variable for a keyword in the environment table of the operating system. If it cannot find the value that you specify, then it returns a null string. Format AEnviron[$](environment-string) The return value for format A is the string that is associated with the keyword. For information about the dollar sign, see Usage of the Dollar Sign. Format BEnviron[$](numeric_expression) The return value for format B is a string that uses the following format: ArgumentsThe following table describes the arguments that you can use with this method. ExampleThe following example lists the strings from the operating system environment table: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
