| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Variable Manipulation Methods > Modify Variable StatementThe Modify Variable statement runs a series of statements on a variable. It does not return a value. The value you specify in the variable argument can be an object or a custom type. You can nest With statements. FormatWith variable The following table describes the arguments that you can use with this method. ExampleThe following example uses a Siebel VB method to modify the values that an object contains if Siebel CRM modifies a field value. The Modify Variable statement references this object: Sub BusComp_SetFieldValue(FieldName As String)    Select Case FieldName          With oBCact          set oBCact = Nothing For another example, see Remove Object Method.  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
