 Siebel VB Language Reference > Methods Reference for Siebel VB > Disk and Directory Control Methods >
Remove Directory Method
The Remove Directory method removes a directory. It does not return a value. Note the following:
- The directory that it removes must be empty, except for the working directory or parent directory.
 - It cannot remove the default directory. To remove the default directory, you must first make another directory current on the drive.
Format
RmDir [drive:][\directory\]directory
The following table describes the arguments that you can use with this method.
    drive  |
    Optional. The name of the drive that contains the directory that this method removes. You can use a letter or a string expression that identifies the drive name.  |
    \directory\  |
    The path to the directory that this method removes. You can use this argument only if the Remove Directory method must not remove the directory from the following locations:
- On the current directory of the drive that the drive argument identifies
 - On the default drive if you do not include the drive argument
    directory  |
    The name of the directory that this method removes.  |
 Example
The following example makes a new temporary directory in the C:\ directory, and then deletes it: Sub Button_Click    Dim path as String    On Error Resume Next    path = CurDir(C)    If path <> "C:\" then       ChDir "C:\"    End If    MkDir "C:\TEMP01"    If Err = 75 then    Else       RmDir "C:\TEMP01"    End If End Sub
