Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Convert String to Uppercase MethodThe Convert String to Uppercase method converts lowercase letters to uppercase letters. It returns a copy of this string. Note the following:
FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleThe following example converts a file name that the user enters to uppercase letters: Option Base 1 |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
