Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Get ANSI String MethodThe Get ANSI String method returns the character string that corresponds to the ANSI code of the character that the charCode argument contains. FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method. ExampleThe following example displays the character equivalent for an ASCII code in the range of 65 through 122: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
