| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Get Left String MethodThe Get Left String method returns a string copied from the beginning of another string. If the value in the length argument is greater than the length of the string that the string argument specifies, then it returns the entire string. FormatFor information about the dollar sign, see Usage of the Dollar Sign. The following table describes the arguments that you can use with this method.
 ExampleThe following example gets a user first name from the entire name: Sub Button_Click  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
