| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > String Methods > Set String Comparison MethodThe Set String Comparison method specifies the default method for string comparisons to case-sensitive or not case-sensitive. It does not return a value. You must include this method in the general declarations section. Note the following:
 FormatOption Compare {Binary | Text} This statement does not include arguments. ExampleThe following example compares the following strings: If Set String Comparison is Text, then these strings are the same. If Set String Comparison is Binary, then these strings are not the same. Binary is the default value. To examine this difference, you can run the example, comment out the Set String Comparison method, and then run it again: Option Compare Text  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
