Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Disabling the Ability to Delete Comments
By default, users are allowed to delete comments. However, some companies may have security requirements making this undesirable. An Administrator can use the On/Off Allow Comment Deletion switch in System Settings to disable the ability to delete comments.
To disable deletion of comments by users:
  1. In your application, select Manage. and then System Settings.
  2. In System Settings, select Configuration Settings, and then Allow Comment Deletion.
  3. Select Turn Off and then click OK.
