Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Allow Task Deletion
By default, users cannot delete open or closed status tasks from an open status schedule. To allow task deletion, you can set the on and off switch to Turn On.
To allow task deletion:
  1. In System Settings, select Configuration Settings, and then Allow Task Deletion.
  2. Select Turn On.
