Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Maximum Task Attachment Size
Task Attachment Size determines the maximum attachment file size that users can upload. This setting helps administrators adapt to work within limitations of the environment in which the application is installed.
You can change the current maximum file size.
To change the maximum task attachment size:
  1. In System Settings, select Configuration Settings, and then Maximum Attachment Size.
  2. In Select maximum file upload size, select a value from 5 MB, with incremental values of 5 MB, up to 100 MB.
