You can execute the following actions on a model, depending on the current state of the model:
Activate: Activates a model. The model definition must be 100% complete to activate it. A draft can be activated to replace the existing active model.
Only users with the role InsightModelCreator/InsightIntegrationArchitect/InsightAdmin can activate a model.Deactivate: Deactivates an activated model.
Only users with the role InsightModelCreator/InsightIntegrationArchitect/InsightAdmin can deactivate a model.Delete: Deletes an activated model. This action is permanent and cannot be reversed.
Only users with the role InsightModelCreator/InsightIntegrationArchitect/InsightAdmin can delete a model.Apart from the lifecycle actions, you can also perform some other actions on the models. See Other Model Actions.
