To create an implementation mapping to a SOA Composite services/references:
Click Create Mapping within the milestone for which you are creating the implementation mapping.
The Implementation Mappings page opens.
Select a SOA connection from the Data Connection drop-down list. If you do not see any connections in the drop-down list, you must create a data connection. See Creating a Data Connection.
This selection loads information about all the composites deployed in that domain.
Expand the required artifact and drill down to the required Services/References/Components.
Select the required entry and click the Edit Mapping icon to define the mapping.
Select an appropriate value from the Operation drop-down list.
Select an appropriate value from the Interaction drop-down list.
This field does not appear unless you select a value in the Operation drop-down list.
The visual representation will not be available for composites built in 11g version of SOA. In that case, only the popup containing the Operation and Interaction drop-down will be visible.
Figure 3-9 Mapping to SOA Services/References
Click Remove Mapping to remove the existing mapping and create a new mapping.
Click Done to complete the process of mapping.
The mapping is done and the first mapping on the Implementation Mappings page opens in an expanded form.
