Click Create Mapping within the milestone for which you are creating the implementation mapping.
The Implementation Mappings page opens.
Select a Service Bus connection from the Data Connection drop-down list. If you do not see any connections in the drop-down list, you must create a data connection. See Creating a Data Connection.
This selection loads all the service bus projects deployed in that domain.
You will see that only the projects that conform to the supported Service Bus feature set (for example, WSDL services) are loaded and available. For a complete list of Service Bus constructs supported for mapping, see Supported and Unsupported Features in Service Bus.
Expand the desired project and drill down to the required Pipeline.
Click the Edit Mapping icon for the pipeline to map.
The service type can be:
WSDL: both Operation and Interaction appear in the pop-up window. Possible values for Interaction are REQUEST, RESPONSE, and FAULT.
Message Service: only Interaction appears in the pop-up window as a drop-down list with the values REQUEST and RESPONSE.
Select the Operation in the drop-down list that opens in a pop-up window.
Select the Interaction in the drop-down list that opens in a pop-up window. The possible values for Interaction are:
REQUEST
RESPONSE
FAULT.
When you select a value for Interaction, you can see a green icon which indicates that the mapping is done.
Figure 3-10 Mapping to Service Bus Pipelines
The mapping is done and the first mapping on the Implementation Mappings page opens in an expanded form.
