5.5 Running Exception - Instances in Error Status Report
The Exception - Instances in Error Status report provides information tracked about the identified error milestones. The instances which have reached an error milestone most recently are reported.
Only users with the role InsightModelCreator/InsightExecutive/InsightAdmin can run reports.
To run the Exception - Instances in Error Status report:
  1. Click the Reports tab or the Reports Tile on the Home page.
    The Reports page opens.
  2. Click Milestone Performance.
    Figure 5-7 Exception - Instances in Error Status Screen
    img/GUID-A5CFB6E6-A6C7-403A-BBE1-E46EF9B289BD-default.png
  3. Select a suitable Report Format: HTML or PDF.
  4. Select one model for which you want to generate the report in the Insight Model drop-down list.
  5. Select one or more Milestone(s) you want to be included in the report.
  6. Select one or more required Milestone Status.
  7. Select the Date Range.
    1. Select a Begin date from the calendar.
    2. Select an End date from the calendar.
  8. Click Run Report to run the report with the provided details.
  9. Click Reset to reset all the fields.
The Milestone Performance Report is available.
Figure 5-8 Exception - Instances in Error Status Report
img/GUID-1C849108-A9CF-437A-82EC-204CD687029B-default.png
