This reference contains a complete description of the Oracle Continuous Query Language (Oracle CQL), a query language based on SQL with added constructs that support streaming data. Using Oracle CQL, you can express queries on data streams to perform event processing using Oracle Stream Explorer. Oracle CQL is a new technology but it is based on a subset of SQL99.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
For more information, see the following:
Getting Started with Event Processing for Oracle Stream Explorer
Developing Applications for Event Processing with Oracle Stream Explorer
Oracle Database SQL Language Reference at: http://docs.oracle.com/cd/E16655_01/server.121/e17209/toc.htm
SQL99 Specifications (ISO/IEC 9075-1:1999, ISO/IEC 9075-2:1999, ISO/IEC 9075-3:1999, and ISO/IEC 9075-4:1999)
Oracle Stream Explorer Forum: https://community.oracle.com/community/fusion_middleware/soa_and_process_management/complex_event_processing.
The following text conventions are used in this document:
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
