The component element hierarchies show the inheritance relationships for the elements used to configure EPN components. The component elements are defined in the Oracle/Middleware/my_oep/oep/xsd/wlevs_application_config.xsd schema and described in Component Configuration Schema and Event Record and Playback Schema.
This chapter presents the hierarchies for the top-level component elements. All of the elements mentioned in this chapter link to descriptions that are in the remaining chapters of this guide. See alsoDeveloping Applications for Event Processing with Oracle Stream Explorer for information about how to use the elements described in this chapter in an EPN.
This chapter includes the following sections, which is also a list of the top-level elements:
All Oracle Stream Explorer adapters have the adapter element and all of its child elements.
adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog
http-pub-sub-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio netio num-threads accept-backlog One of: server-context-path server-url channel (http-pub-sub-adapter Child Element) event-type user One of: password password
jms-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end time-range-offset start duration event-type jndi-provider-url jndi-factory connection-jndi-name One of: destination-jndi-name destination-name user One of: password encrypted-password connection-user One of: connection-password connection-encrypted-password work-manager concurrent-consumers message-selector session-ack-mode-name session-transacted delivery-mode bindings (jms-adapter) group-binding param destination-type durable-subscription durable-subscription-name
edn-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog edl-file schema-file validate package-name metadata raw-xml-content jndi-provider-url jndi-factory user one of: password encrypted-password delivery-mode priority time-to-live durable-subscription-name client-id
csv-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration time-range-offset start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog event-interval unit source-url initial-delay unit output-file append
obr-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog dictionary-url decision-function
channel name record-parameters dataset-name event-type-list event-type-name provider-name store-policy-parameters parameter name value max-size max-threads recording-session-name One of: time-range start end or time-range-offset start duration batch-size batch-time-out playback-parameters playback-parameters event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads One of: time-range start end or time-range-offset start duration or schedule-time-range start end or schedule-time-range-offset start duration playback-speed repeat inject-parameters active channel-name trace-parameters active channel-name max-size max-threads selector heartbeat partition-order-capacity offer-timeout fail-when-rejected
processor (Oracle CQL) name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end time-range-offset start duration rules query view bindings (processor) params
event-bean name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-threads max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration
diagnostic-profiles name profile name enabled start-stage max-latency name collect-interval amount unit start-location application stage direction end-location application stage direction average-latency name collect-interval amount unit start-location application stage direction end-location application stage direction threshold throughput name throughput-interval amount unit average-interval amount unit location application stage direction
rest-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog event-type-name context-path
quickfix-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog event-type default-session configuration config-name config-value description session configuration config-name config-value description
rmi-adapter name record-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration batch-size batch-time-out playback-parameters dataset-name event-type-list event-type provider-name store-policy-parameters parameter name value max-size max-threads time-range start end time-range-offset start duration schedule-time-range start end schedule-time-range-offset start duration work-manager-name netio provider-name num-threads accept-backlog jndi-name jndi-provider-url jndi-factory user one of: password encrypted-password
