This document provides a reference to Oracle Stream Explorer schemas. When you install Oracle Stream Explorer, the schema files are installed in the following directory:
/Oracle/Middleware/my_oep/xsd
This document is intended for developers who want to create Oracle Stream Explorer applications.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
For more information, see the following:
Developing Applications for Event Processing with Oracle Stream Explorer
Getting Started with Event Processing for Oracle Stream Explorer
Oracle Database SQL Language Reference at: http://docs.oracle.com/cd/E16655_01/server.121/e17209/toc.htm
SQL99 Specifications (ISO/IEC 9075-1:1999, ISO/IEC 9075-2:1999, ISO/IEC 9075-3:1999, and ISO/IEC 9075-4:1999)
Oracle Stream Explorer Forum: https://community.oracle.com/community/fusion_middleware/soa_and_process_management/complex_event_processing.
The following text conventions are used in this document:
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
