| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2016, Rev. A E52417-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Customizing Siebel Open UI".
In this topic, you will configure the manifest for the color box plug-in wrapper example. For more information, see "Configuring Manifests".
To configure the manifest for the color box example
Verify that your plug-in wrapper uses the define method.
Log in to the Siebel Open UI client with administrative privileges.
Navigate to the Administration - Application screen, and then the Manifest Files view.
In the Files list, add the following file:
siebel/custom/colorboxpw.js
Modify the manifest for the physical renderer:
Navigate to the Administration - Application screen, and then the Manifest Administration view.
In the UI Objects list, add a new record with the following values:
| Field | Value |
| Type | Application |
| Usage Type | Common |
| Name | PLATFORM INDEPENDENT |
In the Object Expression list, add the following subexpression.
| Field | Value |
| Group Name | Leave empty |
| Expression | Desktop |
| Level | 1 |
| Operator | Leave empty |
| Web Template Name | Leave empty |
In the Files list, add the file that you created in Step 4.
