| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2016, Rev. A E52417-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Customizing Siebel Open UI".
In this topic, you test your modifications.
To test your modifications
Log in to the Siebel Open UI client, and then navigate to the Accounts screen.
Use the Select column to choose five account records, and then click Delete.
Siebel Open UI deletes the records and adds them to the carousel recycle bin.
To restore a record, click the following plus (+) icon in the carousel recycle bin:
Verify that Siebel Open UI recreates the record on the Siebel Server and adds it back to the Account list.
Navigate to the Opportunities screen, then to the Opportunities List view
Verify that the Probability field in the Opportunity form applet displays the color box and exhibits the correct behavior based on changes to values and clicks.
