| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2016, Rev. C E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications". Before starting to set up your Siebel Mobile, you must meet the following requirements.
The installed software for Siebel Mobile is Siebel Innovation Pack 2015.
Install Siebel Innovation Pack 2015 for new installations or for existing installations. For more information about new installations and migration installations for existing installations, see Siebel Installation Guide for the operating system you are using.
For a migration installation for an existing installation, run the Siebel Incremental Repository Merge to update your database to the latest Siebel CRM version 15.0.
Running IRM is necessary after installing Siebel Innovation Pack 2015 as a migration installation for an existing 8.1.1.x/8.2.2.x installation. For more information about using Siebel Incremental Repository Merge, see Siebel Database Upgrade Guide.
For new installations, running Siebel Incremental Repository Merge is not required. Install a new Siebel database for Siebel CRM version 15.0.
All standard Siebel Server and Siebel Web Server Extension (SWSE) configurations have been carried out before you run any Siebel Mobile scripts on the Siebel Server and SWSE.
New installations. Run the standard Siebel Server and SWSE Configuration Wizard tasks to create the object managers and virtual directories for the language or languages that you choose to deploy.
Migration installations. Run the scripts to add the object managers and virtual directories for new Siebel Mobile disconnected applications not present in any prior installation, for the existing installed and deployed languages. For Siebel Application Object Managers, run the object manager script for each language that you are deploying. For SWSE, run the virtual directory script once and specify all languages that you are deploying.
Additional languages. After a migration installation, run the object manager script once for each installed language. If you are adding a new language to an existing installation of Siebel Innovation Pack 2015, then run the object manager and virtual directory scripts for that language, but only after first completing all the standard tasks to install and deploy a new language as detailed in Siebel Installation Guide for the operating system you are using.
For more information, see the following procedures:
"Adding Object Managers for Siebel Mobile Disconnected Applications"
"Adding Virtual Directories for Siebel Mobile Disconnected Applications"
Note: The Siebel Bookshelf is available on Oracle Technology Networkhttp://www.oracle.com/technetwork/indexes/documentation/index.html and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location. |
