| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2016, Rev. C E52427-01 |
![]() Previous |
![]() Next |
View PDF |
To set up Siebel Mobile disconnected applications, review and perform the following tasks:
Review "Load Balancing Support for Synchronization" before setting up Siebel Mobile disconnected applications.
Review "Requirements for Setting Up Siebel Mobile Disconnected Applications"
"Adding Object Managers for Siebel Mobile Disconnected Applications"
"Adding Virtual Directories for Siebel Mobile Disconnected Applications"
"Siebel Application Object Manager Parameters for Siebel Mobile Disconnected Applications"
"Process of Configuring Siebel Server for Siebel Mobile Disconnected Applications"
"Setting Up Users for Siebel Mobile Disconnected Applications"
Set up the business component data filters for Siebel Mobile.
For more information, review "Guidelines for Developing Data Filters for Siebel Mobile Disconnected Applications" and see Chapter 5, "Data Filtering for Siebel Mobile Disconnected Applications".
Set up the default fields for non-UI business component fields.
The Handheld Business Service only downloads fields that are exposed in the UI.To download the non-UI fields, you must configure the field details. For more information, see "Configuring Application Settings for Siebel Mobile Disconnected Applications".
Set up the default Business Objects to extract the business objects and the business components which are not extracted as part of UI.
The Handheld Business Service only downloads business components that are exposed in the UI. To download any additional non-UI fields, you must configure the default business objects in the Administration - Siebel Mobile, Application Administration, Settings view. For more information, see "Configuring Application Settings for Siebel Mobile Disconnected Applications".
"Monitoring Synchronization Sessions for Siebel Mobile Disconnected Applications"
