| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2016, Rev. C E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications".
Siebel Application Object Manager parameters must be set on every Siebel Server that will support Siebel Mobile, and for each language that must support Siebel Mobile disconnected applications. For more information about Siebel Application Object Manager parameters and the Siebel Server Manager, see Siebel System Administration Guide. For more information about enabling Siebel Open UI for Siebel Application Object Managers, see Siebel Installation Guide for the operating system you are using.
The Siebel Application Object Manager parameters settings shown in Table 3-2 are set by default (except for EnableOfflineMode), and are required for all Siebel Mobile disconnected applications.
For Siebel Mobile disconnected, you must set the EnableOfflineMode application object manager parameter to TRUE to enable offline mode for the following applications:
Siebel Mobile disconnected application for Siebel Pharma
Siebel Mobile disconnected application for Siebel Sales
Siebel Mobile disconnected application for Siebel Field Service
EnableOfflineMode is set to FALSE by default. Before you can work in offline mode, you must enable offline mode. The following procedure shows you how to set the EnableOfflineMode application object manager parameter.
To set the EnableOfflineMode application object manager parameter
Log in to the srvrmgr.
Type the following command at the srvrmgr command line for each mobile application in the appropriate language.
For U.S. English for example, type the command as follows:
change param EnableOfflineMode=True for comp XObjMgr_enu
For each language that you want to set up for your mobile application, substitute the language in question for _enu and replace XObjmgr with the name of the application object manager (as shown in Table 3-1). For example, use _esp to enter the command for the Spanish language on ePharmamObjMgr as follows:
change param EnableOfflineMode=TRUE for comp ePharmamObjMgr_esp
Table 3-2 Siebel Application Object Manager Parameters for Siebel Mobile
| Parameter Name | Parameter Setting |
AppletSelectStyle |
AppletSelectStyle="Applet Select" |
EnableInlineForList |
EnableInlineForList=Never |
EnableOfflineMode |
EnableOfflineMode=True |
EnableOpenUI |
EnableOpenUI=TRUE |
EnableSIFocusTracking |
EnableSIFocusTracking=TRUE |
HighInteractivity |
HighInteractivity=TRUE |
ShowWriteRecord |
ShowWriteRecord=TRUE |
