| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2016, Rev. C E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications." To set up users for a Siebel Mobile disconnected application, you must perform a number of tasks. The tasks that you must perform include the following:
Create user accounts and assign passwords for each user of the Siebel Mobile disconnected application. For more information, see Siebel Applications Administration Guide.
Assign responsibilities (user roles) for each user of the Siebel Mobile disconnected application and associate user responsibilities with the application views. For more information, see the following:
"Adding Business Component Filters for Siebel Mobile Disconnected Application Users"
"Adding Business Object Filters for Siebel Mobile Disconnected Application Users"
The Business Components Filters tab in the Administration - Siebel Mobile, Application Administration view contains the synchronization filter settings for business components. If you want to restrict the contents of selected business components to reduce the data set that is visible to your users, then you can change the filter settings in this view. For more information about adding business component filters, see the following:
The Business Object Filters tab in the Administration - Siebel Mobile, Application Administration view contains the synchronization filter settings for business objects. If you want to ensure that users avoid downloading too many records, then you can change the filter settings in this view. For more information about adding business object filters, see the following:
