| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The field control buttons appear in many fields. Table 4-1 describes these buttons. You use field controls to work with records in the Siebel application.
Table 4-1 Description of Field Control Buttons
| Button | Name | Description | Related Topic |
Calculator button |
Launches a calculator for entering amounts. |
Calendar select button |
Launches a calendar control for entering a date and optionally, time, in a date or date and time field. You can also type a date (or date and time) directly into a field. |
Currency calculator button |
Launches the currency calculator. |
"About the Currency Calculator" |
Multiple select button |
Launches a multiple selection dialog box. |
"Associating Records Using a Multiple Selection Dialog Box" |
Single select button |
Launches a single selection dialog box. |
"Associating Records Using a Single Selection Dialog Box" |
Telephone button |
Launches the default telephone application on for your device. This feature is device-dependent. |
None |
